Only takes a glance to see the post count.Yes but its entertaining and look you responded didn't you? So it stands to reason you must have read most of this thread...
But you already knew that.....
the last cabin filter I got for my sonata was a purolator and out of the box it had no arrow .. not sure why. in the past they always had a arrow.. but this one did not .. but the pleats are the pleats on that filter so it does not matter one way or the other.. now on our forester there is a plastic piece that is part of the filter so it can only go in 1 way. but the pleats are still the same.Serious question. Does it make a difference?
Is the Microgard filter a dual layer filter? If it is, then the up direction may correspond to the coarser layer of the air filter, which the fine layer is on the blower side.Here's how I put the filter.
ACCENT like ours . Very easy access .
Arrowgoes towards the blower . That way the outside air is filtered before the blower . This applies to the '18 Accent and '13 Fit Also , TOYOTAs we had were the same . Others may differ .
