The title is the code and message I received using an app in conjunction with an OBD2 devise. The app also lists probable causes
for the code and how to repair. It said in 70% of the times this code is shown the problem was in the ABS wiring harness, so I pulled and found'
continuity was fine. I first unplugged it from the ABS speed sensor and check the plug on the battery side for volts with a multi-metor , key off and on positions for 0 volts. Then disconnected the top of the harness from the abs module and checked the two pins in the module and got the same results. The app says the probability of the sensor being the problem is 20% and 10% for the module. I've never messed with this stuff and don't really know what I should buy but I would appreciate any comments
2015 Toyota Tacoma, double cab, V6, 4WD.
The wiring harness has a two pin connector on both ends
