If feed my bypass filter with a small line off from my remote full flow filter on the input side, and then return it to the output side, will it work as well as a return to the valve cover? The pressure drop across the remote filter is about 3 psi at around 5000 rpm and less at idle.
Good idea, bad idea?....(Ford 4.6l DOHC)
I was going to feed it with the output side of the remote and then return to the valve cover.
Kevin
Kevin
