Buying used air compressors - yea or nay?
Boston
I'm looking at used air compressors, but it's hard to tell how much mileage these things have left on them.
From what I'm able to gather, air compressors are - in general - a repair prone piece of equipment with a high rate of failure. It's hard to tell how much life is left on a used one, yes?
If it uses oil I guess you can look at the oil. Is it clean? Low?
Does it fill up the tank in a reasonable amount of time?
Does the compressor and tank look like they have been sitting outside in the rain? Or does it look like it's been sitting unused in a garage?
Does it look beat up?
I bought a used compressor at a yard sale about 15 yrs ago. It's getting tired but I only paid $50 for it back then.
Only problems I've had with used homeonwned compressors is rust in the tank causing leaks. Finally bought a Harbor Freight new compressor about 10 years ago and been fine ever since.
I have bought several and they were all used; most recently a 5HP gas powered portable; yeah it had a leaky tank but I found a dead compressor (oilless POS) and swapped the engine and pump from the other one over and have 1/2 the normal going price of a typical used one and 1/6 what this same unit sells for new these days; I don't anticipate alot of use on my part for this portable, but enough to justify having my own; one thing I can say go bigger than you think you need; the only time my 80 gallon 2 stage has been too big is when I have needed portable power; but I have had many that were too small that I have wound up reselling. buying used gives you more compressor for your dollar. I do see bare tanks and dead compressors, as well as pumps by themselves on CL; if you are the least bit handy you can pt yourself a NICE unit together for cheap....
There are nice ones on Craigslist all the time. I bought a Dayton made Speedaire with 20 gal tank cast iron pump and dual voltage motor for under $100. Still in mint shape and quiet as a church mouse. They are high maintenance and break down frequently IF they are Aluminum pumps (oil or oiless) and light duty motors.
Looks just like what I bought years ago, only difference I can see is mine only has one air outlet, which is ok as I only use one hose at a time anytime. Same HP and capacity works super and has never given me any trouble.
Remember the new Harbor Freight coupon rules - You can't use the 20% off coupon for air compressors or tool chests anymore. Service carts are still okay, including the 4- and 5-drawer ones.
