+1. I’d be very wary with condos that have all kinds of fees and an HOA to deal with.
The market in this area is very hot right now, so it’s not a good time to do it, IMO. You need to make money at the buy, which means picking it up cheap enough. When the economy goes through a correction and RE settles down, will be a better chance, IMO. Having more money set aside will get better terms, since it is not a primary residence, and so you can’t get as favorable of rates.
In the end you have to do the math, but don’t count on the rent covering the mortgage unless you have sufficient down payment, and at that time, it’s all because you put more of your equity into it.
Its also very market dependent. Some spots will have lower local taxes and lower RE prices, and might be a better bet. So blanket thoughts given on here will not be as accurate as knowing the market locality by locality.
