Buying a borescope
Frisco, TX
Harbor Freight has them for $120. I see cheaper ones on eBay (USB to your laptop) for less. Anything I should be looking for? Any recommendations? Don't want anything too crazy, just want to use it soon to check my cylinder walls during a spark plug change.
Or can I just rent one somewhere for like $40?
The USB ones sound like the're all camera. The HF one you're paying for another screen.
I have used borescopes to do internal engine inspections maybe 10 times over the 25 years I have been in the business. It is difficult to interpret what you are seeing in the scope and to draw reliable conclusions about whether or not some scratch, line, or shadow requires the engine to be disassembled for repair. One time I was certain that I had a cracked piston, and had the head removed, only to find out that the "crack" was a carbon deposit.
Cylinder bores are difficult to read because they are highly reflective, and the glare can totally obscure the cross-hatch pattern. If the light supply can be adjusted to reduce the intensity, that would be a good feature to get. Another nice feature is a right-angle mirror that snaps on the end of the scope.
In the cases where I used them, borescopes provided another piece of information in the decision to continue or stop a test. Other inputs such as degrading performance, high wear metals in a used oil analysis, high blowby, or a mechanical noise had prompted the investigation in the first place.
Well I don't need a 60fps 720p camera. :-p
Thank you for the info, A Harman. Are you saying I'm better off letting an experienced shop scope the cylinders?
I was trying not to, but in the short run, maybe you would be. If you can get a good system for $120, you can't go too far wrong. Just be skeptical about what you see the first couple of times you use it, and use it to supplement your knowledge about the engine's condition that you get from other sources.
What is the diameter of the head unit? Most of them have diameter greater than 14mm if they are priced under $200. If you are buying to look down at the cylinder, you need it be able to snake it through the plug hole.
One of the one from HF has LED intensity control but the head is still too big.
- Vikas
I got mine from Northern Tools. Crystal clear color screen and bright led light makes a very nice and clear view.
- Vikas
First thought when I saw this thread. If you need to inspect bores, it has to have a head small enough to fit in the plug hole, and it has to have a "right angle" adapter on it to actually see the bores. More importantly, a right angle adapter/mirror that doesn't fall off while you are inspecting the bore.
To be fair, a scope tool is of more use for external inspections of engines in tight engine compartments. After the "Ooh, its new" appeal wore off, our shop's borescope sat in a box for a long time with maybe a couple of uses/year.
I have not come across any which comes with a small diameter head. I had limited my search to usual cheap places and cost under 2 bills. No hits.
- Vikas
"Narrow 8.5mm probe fits most spark plug holes"
I have not yet seen it in any of the online sales circular. If it is sale price and 20% can be used, then $160 would be good deal. But it is still over my "fun to have" budget.
- Vikas
