Happy Memorial Day everyone!
In dealing with my severely rusted wheel area on the tundra, I broke off two bolts in the holes of my front passenger side rotor trying to dislodge rotor from the hub. I gave up as it was getting late and not having a big enough sledge hammer. Ive been keeping an eye on the rotor temp and it seems to only run 20 degrees warmer than the other side. Is this something I can not worry about for a little bit or do I need to try and get the rotor off/get bolts out ASAP? I put new brake pads and rotors in the rear with lots of issue after having to deal with stuck wheel and rotors but eventually got the rotors off by using the bolt holes. I just bought a 8lb sledge to assist in my issue and hopefully will do the trick. I have new rotors and pads for the front. I just need to remember to use penetrating oil!
Thanks.
Thanks.
