- Joined
- Sep 5, 2021
- Messages
- 4,893
I'm not sure if you want to watch the carnage or think this is a good idea for a video.I love the chainsaw idea. Video the sequence
Are you going to put it in conduit?
I didn't know there was a class of "direct burial" wire, I will definitely opt for this.Whatever you end up doing, I'd use direct burial wire. Has a much stronger jacketing that's meant to be buried without conduit.
I installed cameras 15 years ago via buring regular wire that are still working, who knows for how much longer though. When the cameras failed I removed the shrink wrap on the BNC (that old) and DC connectors, they still looked like new!
Interesting tool, I'll look into it, much safer than taking a chainsaw to the soil lol.
Good point, I do have my lawn aerated.I personally would go at least 6" down. You wouldn't want issues down the road with using lawn equipment like a core aerator, for example.
Since I'll be installing PoE cameras, they need electricity to power the camera, so I cant do fiber unfortunately. I'll look into grounding and I guess the switch will be a sacrificial component at this point.If you must used copper, make sure you get shielded cable and properly ground it.
Line of sight laser sounds awesome, but I need to power the camera somehow as they will be in the middle of a backyard and far from the house.I managed a number of line of sight laser systems, FSO heads, and always optied for a fiber connection to the inside for lightening protection.
I think we found the solution. I hope I can get this into the CRV or on / off a truck. I'll have to see how heavy it is.He hasn't shared what kind of conditions the ground is, soft turf or compacted ground. And I concur with wwilson about addressing grounding issues.
$60/4 hours to rent at Home Depot:
https://www.homedepot.com/p/rental/E-Z-TRENCH-Cable-Installer-Rental-TP400CL3/316821423
