bum running ranger
ME
New-to-me truck. Has run okay at times. 1994 Mazda B4000 4.0 liter 4x4 Ranger clone, 130k.
MAF sensor looks great, spritzed with genuine MAF cleaner spray. Is a rebuilt.
DPFE sensor is new plastic. Removed, shook it, don't hear any water. (They say condensation curses the things.) Found a bum vacuum line leading to it, fixed.
Has nearly new (from PO) nice blue Belden plug wires. I swapped plugs, had copper champions, put in copper bosches. Old plugs all looked the same; nice.
Exhaust smells gassy. More an unburned gas than a rich, black-soot-smoke gas. I tried adding some unlit propane torch gas in the intake while it idled, no better.
A spark test with an inline timing light and an old spark plug with the electrode broke off (for a wider gap) laying on a ground had blue spark on all three coil packs with no misses.
Fuel pump doesn't sound like it's struggling.
Truck idles okay (but sometimes you can pick up a miss) and goes WOT okay but is juddery at mid-throttle, cold or warm, damp or dry. Is a stick shift so you feel it.
Codes: Love 'em. Pulled them before I started messing with things:
In order: 51,25,22,11,72,17,31,76,17,71,72,17,31,76,17, done. Not a lot of sense there.
Tried various unplugged sensors one at a time. MAF, coolant temp, air temp, DPFE, plugged EGR vacuum. No help.
Thinking of a compression test, but not eager to snake the stuff behind the AC box on the passenger side. May also be able to pull off a fuel pressure test if I can find the equipment.
So... who knows fords of a certain vintage?
This has coil pack ignition, post TFI module era.
Hmm... pulled hose, plugged with pencil, ran around the block. Much less grey smoke from the exhaust. Yeah okay this can't go on for long, don't want this burning up. Inside of hose could be wet, hard to see. Also my nose is getting numb to the smell of gas. Got a match?
Also did a MMO/Seafoam intake treatment then went hooning around at redline in case it's low compression.
Off Topic--sorry I'm no help with diagnosis.
This would be a great line for a Craigslist ad:
Finding conflicting info on codes. If they're 3-digit they start making more sense, about every rich/lean o2 sensor code in the book. Jives with the FPR. Off to get the part. AA coupon FTW!
Maybe a leaking fuel injector.Lightly tapping the injectors with a brass punch or similar and small hammer close to where it goes into the manifold will sometimes free it/them.
Well the FPR cured the gas out the tailpipe, now I have a bog off-idle. Disco'd battery for relearn, then I let the bugger idle at idle and 2k rpm for a while.
Air filter looks great. MAF looks new, checked again. Long plastic tube MAF-intake (great idea ford) has no obvious cracks.
And my starter solenoid is going south. Drat, Advance auto wants $22 for one, their coupon extravaganza still won't make this reasonably priced.
Ford Fuel Pressure Regulators fail all the time. When they do they allow gas to be sucked into the intake manifold through the vacuum hose. Replace the FPR before you try to diagnose the stumble @ idle.
Did the FPR this morning.
Just a thought (too lazy to walk outside) I actually disconnected the main battery lead at the solenoid, it reset my radio clock etc. Maybe there's a + wire going to the computer coming right off the battery + terminal, and, in fact, the PCM does have some learnin' to do. (my battery terminals, while clean and tight, have the lead pretty chewed up so I don't want to undo them.)
Regular rubber. Silicone is on my list, cuz, uh, the old one burned through.
1994 does not use OBD2 diagnostics.
Those are proprietary codes.
I'd clear them - maybe a battery disconnect will do this on your car - it often does. Or try Auto Zone.
But I think you found the problem with the FPR.
In some applications, Ford did start using obd 2 in 1994. I learned this at Napa/federal mogal seminar the other night.
Eric -
I'm sure you are right - there were some here and there.
'96 was when it was actually mandated/ implemented for all cars.
Correctamundo... I'm sorry, I should have stated it as an FYI.
For the record, this has the old school eec-iv connector under the hood.
The mystery of two-or-three digit codes on this eludes. Would welcome an OBDII jack so I could get live sensor data. Not going to go out and get a scan tool for just one beater truck.
