03 ccentury drives great no codes. Idles high in park. Not as high in Drive or Reverse. Idles at 1475 in Park no AC little lower with AC on. Replaced lower and upper intakes + gaskets, mass air flow sensor, temperature sensor, thermostat, dash instrument cluster, head gasket, radiator, water pump, starter, idle air control valve, oil and filter, transmission flush and filter, power steering fluid, coolant, throttle position sensor, cleaned throttle body, ran smoke test and found no leaks all done by licensed shop.
Mechanic reflashed computer and it worked fine for a while then battery died and problem reappeared. Taking back to shop on Monday.
Any ideas for a permanent solution that wont poop out everytime i swap batteries?
Thanks for all replies.
