Hello,
I was just wandering if you have noticed the same when you made your oil change, sometimes when I unscrew the drain plug and the oil reaches the container I have placed below the engine, and the flow becomes thinner(just a few moments before the flow becomes just drops) some bubbles are forming in the point the flow meets the already drained oil , sometimes these bubbles are not there. Does this mean that I should have changed the oil earlier?
thanks for your input
john
john
