Broken dip stick handle on Chrysler Sebring with 2.7
Michigan
Man this just happened to me yesterday on my 2.7! Went to check the oil and the handle snapped off. (it had been getting harder to pull out) I Tried super glue but no dice. Tried drilling it and was going to screw a screw in the plastic to try and pull it out. No go. Finally I took out the one bolt holding the tube bracket. After a short period of twisting and pulling I pulled really hard and the tube came out of the rubber grommet in the block. (The stick tube does have a couple small seals on the bottom of it) After getting it out, I did more drilling to lossen the plastic handle piece and I was finally able to push it out using the end of the dip stick. Tried to find a replacement dip stick but they were hard to find, so I ordered from the dealer.
You have much more perseverance than I do. I'll give you credit for that.
Nobody ever said the 2.7 was the work of a genius. Glad you solved your problem.
Well ya gotta have a dip stick.....
