There is a large amount of oil comming out, when I first noticed it there was a lot of smoke. No PCV valve. No overfill I just purchased a carb breather assembly not installed yet. This is a riding lawnmower
Before you spend too much time on it, pull the head and inspect the bore and see how much wear you have to deal with. If the bore is trashed, you can save time and get a replacement shortblock/engine vs reringing what you have.
Is there no breather valve? That's probably not the correct name, but you may know what I'm talking about. It looks like a little rectangle with a hose coming out of it. Sometimes you can take those off and soak them in gas if the reed gets gummed up.
Replaced the breather and hose with new ones started mower and had the same issue oil coming back through the carb.also puled the plug and did a few cranks and no oil coming out. Otherwise get the mower runs great also I have rebuilt the carb. with a new Briggs parts.
