Briggs plug 696202?
Suffolk County, NY
Today I was looking for a briggs plug for my mower. I needed plug 692051. For a briggs 500E 140cc mower. I know that 692051 crosses with a Champion RC12YC. The only plug they had was a 696202. On the rear or the package it says that it replaces RC12YC. Made in 2021. I'm having trouble seeing if they cross or changed the part number. Can I use this plug? Manual states plug gap should be .20. 696202 appears gold if that helps.
Is one of them platinum? Briggs and Champion offers or used to offer a platinum plug for that application RC12PYC :unsure:
Use Denso IK16TT or Autolite XS3924
EDIT: The pictures just showed up for me. I notice it says "longer life" on the package. That sounds like it might be platinum. Can you take a pic of the entire plug?
Thanks. I also edited the original post to include your photo request. Thank you!
Champion had some gold plugs (though as a gold/palladium alloy, since gold itself is a soft metal), butt I don' think they make them any more. Your plug might be gold, but more likely to be platinum. It's possible that the gold you see is just a plating for corrosion resistance :unsure:
That B&S part number does cross to RC12PYC. Platinum, gold, or iridium can be used to upgrade from the basic copper/nickel RC12YC
The 696202/RC12PYC should be at least as good as the 692051/RC12YC
Do you have your original plug to compare side by side? It should work. I saw a ton of this type plug on clearance at Walmart a couple of years ago and almost picked one up but wasn't 100% sure what it was for.
If using the 692051, the gap should be set to .20. Briggs says not to gap the platinum plug, which is .30. Would this be a problem? Thanks again!
Yes looks the same but the gap is larger on the platinum. 20 vs 30 on platinum
I don't have the same Briggs engine but my rider manual shows 5066 as a Platinum Plug. I will state that I've bought the 5066K Platinum plugs & I have no idea why they add the "K" on some packaging. It sounds like that plug might work for you. Yours is probably around 0.28-0.30" gap.
Has anyone ever actually worn a plug out in a piece of ope regardless of the material it's made from?
Champion losers suck no matter what material they're made from :sneaky:
Also, platinum and iridium plugs *are* easier to start due to requiring less voltage for the thinner electrode. Superior fuel economy is also possible. They are definitely worth it for an OPE.
I doubt it. I really don't think there will be a problem at all with the wider gap with platinum. Most platinum and iridium plugs will say not to gap them. I've never had a problem with them.
Thanks.
