Briggs and Tecumseh engines in the winter......
CT
OK, have a 20 year old Tecumseh and a 12 year old (but
Both are to be used for snowblowing. The Briggs is on a tractor that will also be used during the warm weather for cutting the lawn.
What oil should I use in them? For the winter Id prefer the same (so I can pick up a large jug and be done with it). I was thinking maybe Rotella 5W-40 (we dont get below 0 very often, but high single digits to mid 30's are our normal winter temps). Would that fit the bill for both engines? if not, any suggestions would be appreciated.
Thanks!
-Chris
Forgot to mention (no edit function):
Ive been using Supertech 10w30 synthetic in both of these engines, including during warm weather (cutting the grass).
-Chris
The oil you are using will do a fine job. I would stick with it.
ChrisJH, truth is you could run these machines for 10-20+ years and never see a difference between these two Grp III 'synthetic' oils.
My preference is for the better additive package in the 5W-40 HDEO. Excellent protection and will probably keep the engines a bit cleaner than the Supertech.
