Thought I'd look at some old used oil analysis data I have from my 2012 Honda. I've run Red Line's 10W30 motorcycle oil in it for most of its life. When I started out, they listed JASO MB on the bottles. Later on, they changed to JASO MA/MA2, and in that reformulation I also noticed that molybdenum went from ~650 ppm down to ~425 - 450 ppm. My use was nearly all in the lower Arizona deserts, commuting 75 - 80 miles/day round-trip with almost no surface street riding. I also rode it around for fun, including long trips around the western USA.
Since the metal plates in this bike's clutch are steel, I look to iron as the likely-best used oil analysis proxy for whether there's a clutch wear difference between the MA and MB version of Red Line. I also have some data from Lubrication Engineers' diesel 10W30 here, which had no JASO rating and no API gasoline engine rating. LabOne did all these analyses.
Sadly, the number of miles is not at all equal for the JASO MB run. I didn't used oil analysis every oil change, nor on a fixed interval.
6,400 miles on L-E non-JASO diesel oil = 11ppm Fe, 7.9 cSt final.
1.72 ppm / 1,000 mi
10,000 miles on Red Line JASO MB = 17ppm Fe, 8.9 cSt final.
1.70 ppm / 1,000 mi
5,000 miles on Red Line JASO MA = 6ppm Fe, 8.5 cSt final.
1.20 ppm / 1,000 mi
6,200 miles on Red Line JASO MA = 7ppm Fe, 10.0 cSt final.
1.13 ppm / 1,000 mi
I don't really have any particular point in posting this. It's data that is probably all (or mostly) scattered here on the forum, but I don't recall having put it together before.
If any of you have a better idea of what used oil analysis data one would want to compare to attempt to assess clutch wear, please post it. I won't be doing any more of this sort of comparison work on this motorcycle. For various reasons I no longer put many miles on the bike, so that would in my view be unuseful and pointless.
Is 1/2 a ppm per thousand miles 'excess' wear? Can everyday usage be 'comparable' enough to tease out such a difference? Is used oil analysis repeatability adequate to determine that anyway? I do not think I know those answers, so by all means please use this as validation for whatever you already thought, no matter what that is.
1.72 ppm / 1,000 mi
1.70 ppm / 1,000 mi
1.20 ppm / 1,000 mi
1.13 ppm / 1,000 mi
