Quote:
The DriveGuard was designed to give a Touring tire ride to a run flat tire. It should give you a smoother, quieter ride versus the RE960.
We know that RE960 is a UHP all-season tire. What performance category is this new DriveGuard in?
EDIT: According to a TR rep, it'll most likely be classified as a Grand Touring AS tire. If that's the case, then the above statement isn't much of an accomplishment. Now, if this new DriveGuard tire is smoother/quieter than their Turanza Serenity Plus, then that would be something to be proud of.
The Drive Guard is not a UHP tire...but they make the Drive Guard in many speed ratings (H,V,W). If it offers a better/softer/quieter ride over other run flats, in my opinion ...many people will give up a bit of performance for the positive ride aspects of the Drive Guard
Regarding the Serenity Plus..
"We’re marketing this as a touring tire,” says Robert Saul, senior product manager. Bridgestone is using the Turanza Serenity Plus, a premium touring tire, for comparison purposes. Because the two tires share the same tread compound, they have similar wet, dry and snow performance.
“I’m not going to say they are exactly the same, each tire has a unique characteristic. DriveGuard, even though it’s a run-flat tire, will deliver comparable ride comfort to the Turanza Serenity Plus. It doesn’t mean it’s as quiet and comfortable and serene as the Turanza because that’s what the Turanza excels at so there’s still a reason to have both of those products in our portfolio. But this run-flat tire can run toe to toe with the touring tire and a lot of people would have a hard time telling the difference.”
The DriveGuard tire will be priced comparably to the Turanza Serenity Plus tire in a similar size and speed rating".
