Breaking in a new gun....Glock 42
Man, that brings back memories. I was actually a firearms instructor before an armorer. Was for almost all 40 of my years in service. Also, a patrol rifle and tactical (SWAT) instructor, but the most rewarding was that I was an instructor trainer. One of the things that I stressed more than anything to new instructors, was to recognize how new shooters went about doing things and encourage them to keep doing it (as you say, if it isn't tactically stupid or dangerous). Train with what they are comfortable with, and as long as at the end of the day, the results are the same, keep training that way until it was innate behavior. Who cares if it was not exactly "textbook". Really detested the ones who thought they were above others because of their role, and tried to tell everyone that their way was the best/only way to do things and made anyone that didn't follow them feel stupid. Allowing folks to do things that made them feel confident and comfortable, even if it colored outside the lines a bit, made for quicker response. This dramatically reduced the "thinking" and focused on the "doing", which at the moment of truth, did not lend much time to do the former. Been through many of these situations, and seen most turn out ok because of good response training. Seen a few not go so well too because of lack of training or trying to adhere to formal procedures that didn't feel natural or instinctive.
UPDATE:
So the above pic......
I had a moment to mess with the Glock42 I have been having issues with feeding .....
it seems as though the firing pin / striker is impeding rhe travel of the case whilst the case is on its upward move to feed into the chamber.
It is almost 100% repeatable.
My other 42, does not petrude nearly this much while rhe slide is in motion.
Typically a striker fired gun has a small light spring just forward of the striker to prevent the striker moving forward...... i will be contacting glock again.
it would seem rhat this is a near failure of the firing pin safety or a over engagement of the portion of the fcg that pushes the block upward....
what say you glock armorers?
The striker safety plunger should obviously prevent that from happening, and it should have reset into the safe position by that time in the cycle. Maybe the safety plunger is sticking in the bore and not popping back into the safe position after every round. Machining issue, assembly issue, dirt/lube issue, weak spring, something.
That's that on the corner of the extractor?
When the pistol fires, the slide goes rearward at a very fast speed. The firing pin is flung to the rear as this happens, and it should not be protruding from the breech face at all as the slide moves forward, picks up the next round from the top of the magazine. I could see your failure if you were just hand cycling ammo through the gun perhaps, but not while it’s actually firing.
Take the firing pin out (super easy) and clean the firing pin and firing pin channel of any old lubes that may be preventing the firing pin from sliding properly in the channel. Froglube or bio based lubes are notorious for gluing parts together and should be avoided.
Clean the firing pin and channel and make sure no oils or solvents or anything else are on them. Reinstall dry.
Glock extractors (and some other semi auto pistols) have a little nub that sticks out when a round is chambered. It acts as a loaded chamber indicator. It works good, especially in low light. When you pull the gun out , you can slide your finger over the extractor in low light and instantly know for sure that a round is chambered.
Or get the Ruger 380 EZ Security, I think G makes a G25 double stack which might be ok or P365 380 from Sig.
I’m a huge .380 fan. I have owned most pistols chambered in this caliber.
The Glock 25 (limited release, discontinued, no longer available) is probably the best one I have shot. That or the P365-380. I am a huge fan of these two. Put the XL grip on the P365 and use it with the 12 round mags and it’s sweet.
The Ruger is pretty nice too. Just am not a fan of polymer pistols with safeties so I can’t overlook that (they don’t sell it without a safety).
The Smith EZ 380 is the biggest pipe of junk on the planet. Lots of issues all over the net and it’s this gun and Smith refuses to fix it. Has fundamental design flaws and needs to go back to the drawing board. The 9mm version of the gun is generally ok.
