Hi guys,
I recently rebuilt all 4 calipers + swapped in a second hand BMC.
After bench bleeding the BMC and bleeding the brakes multiple times the brakes only worked at the bottom of the travel so I went and bought a brand new BMC thinking I had a faulty BMC (since it was used).
I did a bench bleed + bled the brakes at the calipers (helper method) and the issue still persists.
The brakes do nothing for the first half of the travel and only work when the pedal is near the floor.
What could this be?
And what should my next step be in testing/fixing this issue?
Brake setup is from a Mitsubishi FTO in a Mitsubishi Mirage 2001.
What could this be?
