Originally Posted By: Johnny248
Originally Posted By: The Critic
Wagner states explicitly on the package to not use anti-squeal.
But use a brush and synthetic brake caliper grease on the pins and the holes on the bracket. Wire brush the hub and the clips on the bracket.
Depends on how your Thermoquite pad is constructed. Not all of them have the integrated shims built in to them. I recall Wagner pads coming with a slip of paper on how to prep each style pad. I normally don't use anything on the molded shim pads, but I generally use "purple" aka Permatex Ceramic Extreme brake part lube on everything else. It seems to work well on everything. Used to use MolyKote when it was free, but it is ridiculously expensive to buy.
I'll have to look - since I just got the pads yest. from Amazon.
But from comments on Amazon, most say the shims are built in & that the factory recommendation is to just lube the 'ears' or 'hangers'.
Thanks for the tips.
