Brake issue again for 2001 Jeep GC
Kuato is right, our WJ's are hard on rotors and new cheap ones won't result in a happy ending. I've got pulsing issues on mine that are getting to the point I'm going to have to deal with it.
Originally Posted By: Inspecktor
Check your rear brakes- In a salt environment rear disc brakes can corrode and pad ears and carrier become one lump of rust. The fronts then do extra duty and can get hot even when driven easy.
Rear brakes are all new.
Originally Posted By: msmoke00
Originally Posted By: The_Eric
Don't assume lateral run out is good on the hubs.
x2 An on the car lathe for the rotors like a Pro Cut does wonders for habitual pulsations.
I have yet to find places with one.
Originally Posted By: Donald
The odd thing is I need to do nothing special to the brakes in my 3/4 ton pickup and they are always super.
Those rotors have more beef in them and probably resist heat better. My experience has been, that any rotor on a car works fine, even duralast, as long as you torque the lugs every time, especially before they ever see heat. And use a good pad. The Akebonos should be a good pad, never tried them before. Usually pulsating rotors are from pad deposits from the brake pads welding themselves the rotor at stops. Better pads prevent this. Since using quality pads on new rotors with a torque wrench , I don't have problems. Make sure the wheel bearings are in good shape too.
I am sure the indy shop is properly torquing the lug nuts.
Ordering these on Amazon: 76793PER.
The Raybestos Advanced Technology rotors came and they look nice. Non directional and a squiggly slot.
Cast in China, finished in the USA.
^^^I have those on our MDX and they have been good^^^
used akebono pads and there is far more "pedal" than there was before, and the feel allows a lot of modulation. previous pads and rotors were dealer-maintained, and I'm guessing a semi metallic based on the previous rotor wear. This current combo is my new "go-to."
I suspect the rotors warped on the OP. centric/power-stop was good, I've heard have gone downhill, and there are allegedly some fakes out in the market under the same name and packaging.
