Is there any benefit to changing the brake fluid in the brake fluid reservoir once a year? My plan is to spray down the brake master cylinder with brake cleaner before opening it, then use a vacuum extractor to extract the fluid out of the reservoir, and then replace the reservoir fluid with fresh brake fluid (DOT 3 in my case) up the the full line.
My thinking is that it would keep fresh brake fluid in the system and prolong its life.
