You guys gotta realise that attitudes towards servicing differ a lot each side of the Atlantic. In the US, as well as main dealers, you have individual "shops" for each area of competence- brakes, muffler, transmission. We don't have these so called specialists, we have main dealers , independant general mechanics, and tyre/ muffler/ brake/ shock/ oil change qwik- lube type places. I believe our service schedules aim at more preventative maintenance-
No- one in Europe would have drums or discs turned, few rotate tyres, and unless you're looking at a classic or obsolete vehicle, brake parts (calipers, cylinders) are replaced, not rebuilt- OK sometimes exchanged for factory rebuilt...
So a regular fluid change DOES help the longevity of the system. No sense having your brakes rusting from the inside out! Plus safety is an issue- our speed limits are higher, so more heat is generated in a panic brake.
Remember, leaving fluid in the system for many years then doing a pedal to the floor flush/ bleed is a great way to shred the seals in the m/cyl as they pass over the rusty end of the bore you don't normally use...
