Brake Fluid Flush Technique
Originally Posted By: jk_636
Easiest method to flush the brake system? Thats an easy one.
Step 1. Drive to an authorized BG service center.
Step 2. Pay money for brake flush and service.
Step 3. Drive home.
It is as easy as 1,2,3!
While there, you can have you injector, intake, transmission, engine, differential flushed. Did I miss anything else that BG does? I mean it is important to make sure BITOG knows about the BG products.
Disclaimer:- I do NOT know any BG company stock in my portfolio
Flushing any loose junk out of the caliper would be a good first step. Pushing the piston in right away is a good way to get it jammed. There is enough turbulence within the calipers to flush out all the fluid.
Step 3. Drive home.
You forgot the coolant service! And yes, BG products are a great option and I am surprised they aren't discussed more on here.
