I assume he means they were never replaced while HE owned it. The only cars with rotors that last that long are hybrids or those with ceramic rotors.300k on them? Crazy! (even if kilometers) Do you happen to always stop the car Fred Flintstone style with your feet on the pavement? If so, what brand of shoes do you wear?
No rust whatsoever on itIf the disc looks smooth and no grooves or rust you are probably safe continuing to use them. Doubtful if you will wear them enough to have them below minimum thickness. That typically comes from machining the disc.
Many people in the rust belt end up having an issue with the pads or caliper caused by rust or corrosion that screws up the disc.
I doubt that in Egypt the OP will have that kind of issue.
It has been sent to a special workshop to sweep a layer off of it as it was causing issues with the breaking pads causing it to whistle and wear off prematurely now it is smooth as baby skin but cant say the same on the backsideAs long as they are within the thickness they will be fine and not too grooved.
Never replaced since 1998 as i had the car when it had 40k on the odometer and the previous owner didn't do much work on the carI assume he means they were never replaced while HE owned it. The only cars with rotors that last that long are hybrids or those with ceramic rotors.
