Originally Posted By: JHZR2
Originally Posted By: AcuraTech
I've bled hundreds of various Honda cars with this sequence without a problem.
Stupid question... cant you really bleed any car in any sequence, without a problem, provided the fluid is all clean???
If you have dirt in your MC, whichever sequence you go through will find the dirt traveling to one of the solenoids in the ABS pump. The key is to rid yourself of the dirt at the caliper end, and whatever may have migrated up.
My understanding of the job was always to remove all fluid at the MC, replace with clean, then flush.
SO im not saying that it does not matter, I am just asking, in theory, so long as your MC reservoir is clean, and youre pushing clean fluid, why it would really matter, so long as clean, fresh fluid comes from every caliper bleeder.
Thanks,
JMH
I agree that bleeding sequence is probably irrelevant. One of those admonitions that may have had some validity sometime in the past, but logic long since forgotten. I usually just do RR, LR, LF, RF in clockwise pattern.
On a side note, I've noticed that my 99 Subaru Forester brake fluid stays nice and clean (still clear amber color w/ 185K miles) while my other cars brake fluids are all dark until I replace, and shortly turns dark again. Perhaps Subaru has a better brake fluid? What could that be?
Regards
