Originally Posted By: tvl
OK, that's what I wanted to see. Someone who has USED the simpler pressure bleeder and has experienced NO issues. I do believe this fact alone will sway me towards the pressure bleeder.
But, just so that I can say that I asked, have you ever tried the vacumm type (such as Mityvac). What are the pros and cons of this type unit?
Thanks soooooooo much!
I've used the Motive #108 on my Saturn with great results. Prior to starting the flush, I pump the pedal (1/2 stroke) several times until the pedal firms up. I use 20 psi and during the flush, I tap the caliper with a rubber mallet to dislodge any trapped air bubbles. I have used a Vacula branded vacuum bleeder before (compressed air operated), and for a few years my pedal felt a bit soft. I thought it was normal, but after a service with the Motive bleeder, the pedal firmed up considerably. Therefore, I believe that vacuum bleeding introduced air into my brake system.
1- What have you found to be the easisest way to deal with a situation like this?
2- I was about to place an order for the Motive bleeder model # 0107 when I noticed they carry a red label and black label model. The red label unit is model 0107 and comes with a plastic cap. The black label unit is model 0117 and cost only $10 additional. It boast a custom machined aluminum cap. Is this a better cap for sealing or whatever?
Thanks again!
1. Use plenty of penetrating oil and a six-pocket socket to snap the bleeder screw loose. I flushed a Saturn and a Toyota for the first time in 15 years. I did not use penetrating oil on the bleeder screws and I had no trouble loosening them. However, I live in a very mild climate and neither of the cars have ever been exposed to snow or salt.
2. Like Mori says, I doubt it even matters. Perhaps if you worked at an auto shop and used the bleeder on a daily basis, the aluminum cap would last much longer. But for occasional use, the aluminum cap is not needed.
