Been following this from the start, you do great work @JoeDirt41 . Your progress and successes are inspiring for sure.
Glad you’ve enjoyed following along! It’s been a fun little, low-budget project car!Been following this from the start, you do great work @JoeDirt41 . Your progress and successes are inspiring for sure.
Thank you for following along! I’m glad you’ve enjoyed it. I enjoy updating it just for my own documentation purposes, and I always like reading everyone’s feedback and ideas on how to improve. It’s been a lot of fun to work on and it’s really a great car to drive.Thank you for continually updating this thread, been a real treat to see the hard work you've put into it![]()
so where's it leaking in the power steering system? I remember you replaced the power steering pump with one (no-name chinese) like the one I had in my civic of the same vintage. but thanks for the update, nice to hear all is well (except for the leak)..School started this week so I’ve been using the car to commute. It has been in the single digits in the morning when I leave and the car hasn’t complained much about the temps. Takes a couple extra seconds of cranking before it turns over, but it starts right up. Yesterday I put a full tank of ethanol-free 90 octane in it, just for the heck of it. I doubt the car will notice but I’d imagine it is higher quality fuel than our usual E10.
I got some nicer floor mats to keep the mess from the salt and slush to a minimum. The thin mats I had were included with the car and just weren’t good enough. I’ve had these Members Mark mats from Sam’s Club in several other vehicles and they are about the best thing other than WeatherTechs. Driver’s side is a little big but it doesn’t interfere with the pedals so I’m fine with some extra spill protection.
View attachment 321019View attachment 321018
One of my Carquest XQ wipers broke after freezing to the windshield, so I had to get a replacement today. The cheap plastic rivet that holds the clip seems to pop out and then the wiper frame bends. Bad design. I need to find some conventional blades with a peened or rolled metal rivet.
I also added some AT-205 to the power steering fluid in hopes of stopping the small leak. I added 3oz per the instructions. It claims that I should notice results within 5 hours of operation. Lots of good reviews on this stuff so I’m hopeful it works.
View attachment 321015View attachment 321016
The power steering is leaking from the pump, unfortunately. Can’t tell if it’s the shaft seal or the pressure relief valve cap on the bottom. I don’t notice the fluid level going down, but it’s enough to make a mess on the timing cover. Definitely annoying. I have the old pump if I want to try to put seals in it again and switch back, but I’d like to see how this leak stop does. I’ve read a lot of good reviews on it.so where's it leaking in the power steering system? I remember you replaced the power steering pump with one (no-name chinese) like the one I had in my civic of the same vintage. but thanks for the update, nice to hear all is well (except for the leak)..
oh and it'll be interesting to see how the ethanol-free gas works out for ya.. I know on the civic it gained about 3mpg with that fuel.
I know you get the wiper blades probably on a discount but I remember going back to Honda's blades and the wipe quality was excellent, thinking it was a metal frame too. But that's if you get a good discount at a Honda dealer.
Thanks! And thanks for following along! I wonder the same thing myself. I read up on it a lot, and I really couldn’t find any negative reviews of this product. The really nice thing about this car is that it’s a second car and I’m able to experiment with stuff like this on it. Worst case, I can drive my truck until I find the time and parts to fix it.Such a great job keeping this classic alive. And a fun thread for sure! I always wonder if there’s a risk of adding chemical seal softeners, for the impacts they might have on other seals in the system. Will it weaken others and shorten their life? Might not matter?
and here I thought that no-name pump was good, guess I got lucky for the Civic with one of those. sorry it didn't work out for you. But it will be interesting to see if this stop leak stuff works!The power steering is leaking from the pump, unfortunately. Can’t tell if it’s the shaft seal or the pressure relief valve cap on the bottom. I don’t notice the fluid level going down, but it’s enough to make a mess on the timing cover. Definitely annoying. I have the old pump if I want to try to put seals in it again and switch back, but I’d like to see how this leak stop does. I’ve read a lot of good reviews on it.
We get lower quality fuel in the winter so I figured I’d see how the ethanol free stuff stacks up. Might help, definitely won’t hurt.
The beam style blades don’t fit well on this car; they don’t wrap around the contour of the windshield well enough, so I prefer the conventional blades for it. I know the OEM Honda blades are good. I went for another Carquest just because the other blade isn’t very old and I don’t want to replace it, and my OCD would never let me have mismatched wiper blades. I hate Rain-X blades and those are the only other conventionals that I’m seeing in stores but I haven’t checked thoroughly. I’ll look around more next time I get blades, probably in the spring or summer.
yup bitter cold temps always shows suspension issues. You know everyone is going to tell you to put Bilsteins on it!I’ve put about 200 miles on the car since I put the AT205 in the power steering system and I think I have some good news to report. The leak seems to have either slowed significantly or completely disappeared. There is very little fluid on the timing cover and upper engine mount where it was previously soaked in fluid. I’m very happy with this result. I’ve noticed no negative effects on the performance of the power steering system since adding the AT205.
View attachment 322692View attachment 322693
We’ve been in an arctic deep freeze for the past couple weeks with lows around 0, dipping into the negatives and we even got a foot and half of snow to go along with it. The car has performed well on less-than-perfectly cleared roads. The tires are still in great shape, so that helps a lot.
The temps have made it really hard to wash the salt off of the car, but I did pull it in the garage yesterday and hosed it off as best I could with hot water. Even in the garage with hot water, the water was freezing as it hit the car. I was able to rinse off a lot of salt and debris though. I really hate winter!
I got at least one good picture of it while it was still clean on my way to class this morning. It was filthy after the drive home
I believe these winter PA roads are starting to take a toll on the suspension, as I’m getting a dull “pop” noise going over bumps. Sounds like a strut mount to me, and I haven’t narrowed it down completely, but it seems like it’s coming from the left front. I haven’t replaced the struts on this car yet, and they are still the originals, so come spring, new struts are probably in order.
You’re doing great with this old civic. I lived in Detroit for years, and I always had a winter beater. Word of advice though, if you use fluid film, don’t bother washing off the salt. It doesn’t help, unless you’re doing the exterior for cosmetic reasons. The fluid film is a barrier between the salt and metal. Washing only risks removing the film.I’ve put about 200 miles on the car since I put the AT205 in the power steering system and I think I have some good news to report. The leak seems to have either slowed significantly or completely disappeared. There is very little fluid on the timing cover and upper engine mount where it was previously soaked in fluid. I’m very happy with this result. I’ve noticed no negative effects on the performance of the power steering system since adding the AT205.
I’d love to put Bilsteins on it, but I don’t believe anything from Bilstein is available for this car anymore. KYB had their adjustable AGXs for it as well as standard shocks. And I believe Tein makes coilovers for it. OEMs are long discontinued. There’s really not a ton of options.yup bitter cold temps always shows suspension issues. You know everyone is going to tell you to put Bilsteins on it!
And with the extreme cold that would shrink o-rings in the power steering system and show leakage, you're new fluid condition it and stopped it. Talk about a nice commercial for that stuff! I'm thinking if I have issues with my own car I'll be looking at using that stuff! No money right now for a huge repair bill!
But that's awesome that the at205 stopped it and I can't see anything on the timing cover either, looks bone dry! cool!
yup this winter has sucked more than others! nice morning, parking lot picture, reminds me of many mornings going to college. what's wild is your picture doesn't have any huge, modern SUVs in it.. that picture looks like it could have been taken back in 97 when the car was new! very cool.. ok thanks for the update.
