JHZR2
Staff member
In the lowered position, of course!
Planning to get started taking apart the cv axle and rear hub on my 82 Mercedes. Not a lot of space to jack and place jackstands, especially since I'm doing it up on a kwik lift..
I borrowed a neighbor's bottle jack to lift up the corner and remove the wheel the other day when investigating. I lifted at the subframe bushing shown in the second picture. As you can see, there's not much of a place to put a jack stand. I might be able to finagle to lift the rear of the car by the diff, but it's already 26"+ in the air.
To me, the obvious choice would be to lift by bottle jack, then just lower the bottle jack to resting position, and use it as a makeshift jack stand. Yes, the base is a bit smaller than a "regular" jack stand, but I can back it up with wood or another jack stand in an "undesirable" location as a backup or backups. Three tires will be on the lift bearing weight too, so stability isn't a huge concern.
The other option is to put my ez car lift on the kwik lift bed and lift the whole side and just use that to support... but then I'm lifting the side and it seems like a more clunky way to go.
So, any reason against this approach?
![[Linked Image from i.imgur.com] [Linked Image from i.imgur.com]](https://i.imgur.com/5HsqqMql.jpg)
![[Linked Image from i.imgur.com] [Linked Image from i.imgur.com]](https://i.imgur.com/QGJtw7Tl.jpg)
