Boslla Bullet LED Headlights
Originally Posted by Surestick
Originally Posted by billt460
If I get busted after the installation, I'll do my best to report from prison. But that will obviously only happen if they stick me in one of those minimum security joints that allow Internet access. But seeing as I would go down for illegal LED lighting, They'll most likely send me to Colorado's Supermax. No Internet there. Just my new wife, Bubba. Then I'll need you guys to send me cigarettes to avoid sexual enslavement.
You're wouldn't go to jail for it but could face fines or even get your vehicle towed.
The way I see it is you have some choices:
The anti-social idiot choices:
- Just say screw everybody else and install cheap LED bulbs that will put other drivers in danger due to excessive glare and possibly put you in danger because they look bright but have no throw.
- Spend a more money for quality LED bulbs as described by Skippy722 above and probably still cause some excessive glare for other motorists as your headlights are still putting out more light than designed.
The smart choices:
- Install additional driving lights that are either controlled separately or in conjunction with your high beams and leave your low-beams stock.
- Upgrade just your high beams (only works if your vehicle uses separate bulbs for high beam and low-beams).
This. I'll even admit, you might spend the money on some good LED's, and they may not work if you have reflector style headlights. Mine are projectors. Headlight aim is also incredibly important. I generally follow this for bulb upgrades. An h11 to h9, 9006 to 9012, or 9005 to 9011 upgrade will give you identical beam pattern to their weaker counterparts. I ran 9011's in my 300 for a year, it's supposed to have 9005's. My SL1's are not really any brighter than the 9011's, I just wanted whiter light.
https://www.hidplanet.com/forums/fo...ns/1409801-ryan-s-guide-to-halogen-bulbs
I just learned something. All the headlight part websites, I mean ALL of them (Oreilly, Autozone, Amazon, & RockAuto) say mine uses H11 halogens. Not true. Mine is Xenon HID D8S part number, from the Owner's Manual.
Interesting how HID is slightly more efficient than LED headlights. The 25 watt LED H11 headlights might not quite match the light output of the OEM stock HID headlights actually. In fact, other LED replacements run at 30 watts, so HID's win this in general.
Don't forget that the ballasts are not 100% efficient. High end ballasts are ~90% efficient. That pushes you closer to 27.7w to output 25w. But still a win for HID, and they're likely brighter at 2,000 lumens!
its the "I2R" heating effects that kill efficiency in 12v (low voltage) applications of LED's like this. .. Notice at home, your LED light bulbs run at ten times the voltage, and are very efficient compared to incandescent. Walmart has a 6.5w LED bulb that does the light of an old 60w incandescent at 120v. ..... That level of efficiency is harder to do in automotive 12v lighting since current amps are so high, and that term is squared when running through the attached electronics at I2R. This is why automakers really want 48v systems, not the old 12v setup. Get the amps down.
