Originally Posted By: Shannow
Originally Posted By: SteveSRT8
I have run Edelbrock's water injection setup on street cars since the late 70's. It is GREAT for controlling combustion temps and pre-ignition issues. Worked especially good on old style heads.
We used 50-50 water/alcohol. Many issues with clogging and other small things to keep it running, but it worked well. I could add tons of advance to the timing and still not knock...
Back in the day, I was (for want of a better word) technical advisor on a low buck Hillman Hunter Hill Climb sports sedan, big turbo, big boost, single 1-3/4" S.U. carb 1725cc 4 potter.
We came up with a boost sensitive water injection system by porting boost to a pressurised tank, which then fed water into the turbo intake through a basketball needle...worked great...high speed enrichment, pull the choke on, and the SU carb would drop the jet that the needle sat in and get the lambda back somewhere reasonable.
(the guy later adapted a Haltech to it himself, which I was pretty impressed with)
Water has a surprising effect on power in many cases. Tolerance level varies per platform, but I have seen real world increases. Small, but with the added bennies of cleanliness and low egts it's easy to like if you are a serious enthusiast...
