I always use oem filters because some aftermarket filters will cause engine noises(true story)
I ran out of oem filters.. So I snagged a bosch oil filter from o'rielly www.oreillyauto.com
Seemed well made... well fast forward 2 weeks I had the accent up on ramps for a transmission drain and fill...
The filter was weeping from the gasket.. about 2 drops a min... had a nice mess to clean up.
replaced with an oem filter. I might expect the gasket to weep on a 3$ filter but not this $8 bosch filter.. oh well I guess statistically there will be defects.
In other news the car was at hyundai for a recall.. and for some reason someone put a wrench on the transmission drain plug and overtightened it... and rounded the end of the plug.. it was also leaking.. because they overtightened it so far it sucked in the crush washer.
Now if you arent familiar with hyundai crush washers they are hard aluminum? non-crushing type. The one on the transmission plug was totally destroyed.
Now why would hyundai dealer tighten the drainplug?? or even touch it.
