So you are at the parts store and you notice that there are two versions of the Bosch filter. The distance plus is a couple bucks more and in a blue can versus the black can of the premium. Both filters are expensive and you are wondering if there is a difference. I cut open both (the D3312) and found that there is a difference between the two.
Premium - black can - 720cm2 of filter surface area. The o-ring looks rubber. The internal vents in the tubes, silicone o-ring and leaf spring look to be the same as the distance plus....
![](https://bobistheoilguy.com/forums/attachments/usergals/2017/05/full-19690-7438-bosch4.png)
Distance plus - blue can - Same 720cm2 of filter surface area. I cant tell if there is a difference in the media? You get upgraded silicone o-ring and much thicker can. The spring and the vents look the same. If the oring and can are worth it to you, this is a superior filter.
![](https://bobistheoilguy.com/forums/attachments/usergals/2017/05/full-19690-7439-bosch5.png)
