Bonneville Speedweek Audio Stream
the canyons
So I'm helping friends run their Streamliner here on the Salt Flats, and thought that there might be some here that would like to hear the commentary, and the chance to hear bikes and cars go by at speed. There is some downtime between runs. Speedweek lasts through this coming week, unless weather or course conditions dictate otherwise.
If you are on or very near the Salt Flats, this is also being broadcast on 89.3 FM.
Anyway, the link: Speedweek Audio Stream
Originally Posted By: Garak
I'd check if I wasn't up at weird hours. Maybe I can find a YouTube channel or something with some past streams. That would be a wild place to visit!
Lots of past audio streams here: Landracing Audio Streams
Listening is certainly not the same as being here, but it gives a little taste of the goings on. The Salt Flats are a harsh environment. It's easy to get sunburned and dehydrated in short order. But if you're a gearhead, it's hallowed ground. There are teams here from around the World.
A little while ago the Turbinator streamliner came past the pits on a run with an exit speed of 470 mph.
