Hello all... I recently purchased a 99 Corolla with about 160k miles and there were no signs of oil consumption at the time of purchase. After driving it for a bit I noticed it was burning about 1qt every 700 miles. To try and remedy this a person close to me whose name I won't mention put in a bottle of Autoguard oil treatment to try and slow down the burning. After I found this out I wasn't happy and as a result the car is now burning a qt. about every 250 miles. There is white smoke that will puff out of the exhaust only after I take off after sitting at a stop light etc. with the car idling... no smoke on highway. Engine runs great otherwise. As many of you know this car was made with pistons with too few and too small of drain holes. I suspect the Autoguard treatment sped up the sludge/drain problem with the pistons and engine in general. I suspect the white smoke is from blow by. There are no leaks. I used a high dose of Redline fuel sytem treatment which seems to help a bit. I don't have the money to tear into the engine so I ordered a couple bottles of Neutra 131 and am thinking of mixing with some ATF as Bobtheoilguy demonstrated in an old thread. The pics he posted were night and day just from 800 miles of driving. He said he used 12 oz of neutra and a quart of cheap ATF to replace a qt. of oil. The neutra was poured in last. I have never seen an engine look as clean after the pics he posted. Any thoughts if this sounds like a practical solution to stop the smoking/oil burning? I'm thinking of doing this with a couple of oil changes. Auto Rx takes too long in this case to clean and it would get burnt up way too fast to do any good before the required miles. Apparently Bob said he used to sale cases of Neutra to Toyota dealerships to remedy the piston issue? Thanks for your input.
