- Joined
- Aug 25, 2023
- Messages
- 13
Hello all,
I recently picked up a 2001 Z3 2.5i as a weekend roadster. The owners manual states any oil with an API SH or newer is fine, and recommends staying within the 5w30/5w-40 range.
It does not mention LL-01 or LL-01FE.
Correct me if I’m wrong, but all LL-01 oils carry a higher API rating than the manual requires so they should be up to the task of properly lubricating this engine.
Most sites like FCP recommend using a 5w30 or even 0w30 oil since those carry the latest BMW certifications. Even Amsoil’s site pushes 0w-30…..
I prefer the HT/HS characteristics of a SAE 40 weight oil so I’d like to run 5w-40. I don’t care about the efficiency gain from running a 0w30 oil. I care about maximum protection.
As an Amsoil preferred customer, I get a smoking deal on their Euro 5w-40 oil which carries API SN, BMW LL-01, ACEA A3/B3, A3/B4. This is what I’d like to run, unless anyone can prove why that isn’t a good idea.
@Pablo, can you speak into this?
Thanks!
Thanks!
