You only need a long-life oil for extended intervals.
Originally Posted By: fdcg27
That is a cool tool!
Interesting how API SM isn't even close to BMW LL-98.
It is possible for a product to exceed the labeled designations, such as SM oils, semi synthetics and even some otc synthetics. Take the comparison of Mobil 1 0w-40 and regular Mobil 1, both are pretty good, from the same product line, but you also have to say regular Mobil 1 is better than the SM spec it's brewed against. People use regular Mobil 1 in BMWs all the time, in an uninformed method, and no real problems.
Other oils like HD or blends can and do meet generic ACEA specs* w/o being tested against it for the label. I could run the newest oem spec low saps oil in some of the applications I have now, but am going with some highly additized synthetic race and HD oils instead, despite the spec comparator!
So, the spec comparator is one thing, but it doesn't tell you everything about every oil, like the ones I mentioned as well as AMSoil and Redline too. I'm pretty sure what we get here as "Edge", is an stronger and better version of the latest Euro spec oils. "Ultra", what's that marketed for, SM spec Colbalts w/olms? It might just work in a Euro application, just like other SM spec oils.
*GTX 10w-30 and Castrol Start-Up meet A3 in Europe and Delo 15w-40 carried A3 before in USA as well.
