Fowway...excellent post. Used to have great results with BMW's previous synthetic 5-40. It was discontinued when the newer 5-30 came out. Definately not the same stuff. Wish I discontinued it earlier...especially when my 1994 doesn't even spec. a 5-30 for temps. over 5C.. The 5-40 would do 10k easy with only 1 qt. in between. The 5-30 would require increasing amounts...I stopped when requiring ~2.5-3 qts....something wasn't right.
So I switched to Havoline synth. 5-40 for a couple intervals before trying M-1 15-50 and the 0-40. Also tried M-1's 5-30 for a brief moment. I was afraid to continue to much with either 5-30 or 10-30 because they are not A3 oils.
So I then tried Delvac 1. This seemed to really clean things out, but in returning to 15-50, the car continued to run sluggish and in reviewing the SuperSyn specs, Mobil elected to make the 15-50 even thicker than before! In either case, the car consumed all Mobil grades (Delvac the least). Even the 15-50 was consumed at 1qt/1k mi.. Some of it I attest to cleaning...the rest...? In either case, there was considerable engine valvetrain noise with Mobil oils (except for Delvac) which I didn't like. It was greatest with the 0-40.
So I switched to Castrol Syntec 5-50. The car never ran better. I'm not going to vouch for the other Syntec grades, but the 5-50 is A3, cranks in -25C weather, has almost zero burn-off (consumption is WAY down...something like 1/2qt./5k mi) and the engine is quiet.
The 5-50 looks like it's in very good condition after 5k. I think it can readily go the full 10k (factory interval) which is my goal.
Not sure about the new models. I know maintenance was free for the first couple years and if they include the oil, you could always to an extra oil change at 5k. which will ensure cleanliness and longevity PAST the warranty period (which IMO is the end point as far as manufacturers are concerned).
I think there's some confusion with the "newer" oils....even though they may be A3 eg. SLX 0-30, they cannot replace the robust nature of the 50 weight oils I think are required to go the extra mile.
What's interesting though is the M-1 10-30 was apparently the oil used in the million mile BMW. Maybe this is what we should be using, although this is the only grade I haven't tried...I figure like the 5-30, it's too thin and I want as close to zero consumption as possible regardless of driving style for the duration of the 10k mi. interval.
From what I have noticed, don't think you can go 10k mi. with a 5-20, 0-30, 5-30 and have zero consumption. This is why a 40 or 50 weight is necessary.
