Block test -- combustion gases
D60
Colo
I was recently playing around with an EJ25 (so we all know the outcome) but thought I'd point out the block testers are kinda difficult to read -- or at least it was for me.
Also, I realize the accuracy of these is questionable and even hotly debated in some circles. If you want a hot debate....well, I don't care that much.
Take note of how the fluid begins:
I swore I saw the fluid become lighter during the test, but it still has a light blue hue to the eye. It's supposed to turn yellow if positive. I found using a light helped to show contrast to the naked eye.
I'm gonna call this positive for combustion gases:
There are other things to back up my finding, although I didn't bother with a leak down. Basically I personally wouldn't rely solely on this, but used it as a sanity check to confirm my conclusion based on other things.
Unfortunately, I have to agree with you. Positive test.
Don't feel bad, not my vehicle! I can't touch it for a month. It'll be my first time doing boxer HGs and I'll have lots of questions in the next few weeks as I compile parts :)
I know WatchWesWork had a diesel where the fluid wouldn't turn colors at all, he was using the diesel-specific fluid and nothing.
Yeah I remember that one, which is why I don't think they're the final word.
In his case he got a false negative. I'm not sure if they can also have false positives.
I read some are not for diesel engines and the test can be corrupted if even a small amount of coolant is drawn into the fluid.
These test are definitely not the be all and end all but if one changes color it is a pretty sure bet combustion gases are entering the cooling system.
My sympathies, at least the engine is easy to remove and reseal nearly everything on a hoist/stand.
Also if this test is ambiguous, the engine and heads are salvageable.
I'll get to use my new HF gear driven engine stand. I can be like I Do Cars!
"It's fine"
