yuthanasia
- Joined
- Apr 30, 2021
- Messages
- 24
Duralast (motorad) thermostat didn't open in the water until 200F, and didn't fully open until boiling so I pulled it and ran with no thermostat, same thing, WHAT THE ??? I even took the slack off the serpentine belt and tried to see if there was any play with the water pump pulley, nothing, solid as can be. This has to be the water pump or coolant temp sensor, engine temp sensor whatever it is right? I can recreate this issue much quicker by turning the AC on full blast while driving at 4k to 6k RPMs for a couple minutes...that might seem harsh but really it shouldn't get 3/4 on the gauge from just that, something is up.
I'm going to order one of those no-spill funnels, install the new oem thermostat and run it with the funnel in for 45 minutes...if that doesn't do it then there's literally nothing else but the pump, or some temp sensor.
