Hello all. So my girlfreinds dad has a van that needs its brakes bleed but I guess im unsure on how to do this. Today I tried the two man bleed and I think it did it right but all I got was frustration and a little bit of clean fluid out of the bleeder. Ok so this is what i did. Filled res with clean new dot 3 (what the vehicle calls for) cracked bleeder on rear left (furstes from master cyl) had gf press on brake untill fluid stoped flowing. closed bleeder. released brakes. opened and pressed again. and repeated this process untill I started getting cear fluid. But I could still hear a squirting sound as if air was in the system and the brakes werent firming up how I would like them. Am I doing this wrong? Also I was thinking about getting one of those one man bleeder kits. his is the one I was thinking about getting http://www.autozone.com/autozone/accesso...fier=46839_0_0_ does anyone have any luck with this kind of bleeder? most of the people I have seen do bleeding besides the two man bleed use a vacum pump http://www.harborfreight.com/brake-bleeder-and-vacuum-pump-kit-92474.html Can anyone tell me if im doing this wrong and if I do go with one of the bleeder tools with the cheep oem one work or should I save and get a nicer vacum one (perhaps not the harbor freight model but something similar)
THANKS
Sean Scott
THANKS
Sean Scott
