Quote:
cracked bleeder on rear left (furstes from master cyl) had gf press on brake untill fluid stoped flowing. closed bleeder. released brakes. opened and pressed again. and repeated this process untill I started getting cear fluid. But I could still hear a squirting sound as if air was in the system and the brakes werent firming up
You missed a couple of steps.
--Put a smear of grease around the threads of the bleed nipple so it doesn't suck air around the threads.
--Put a plastic tube or hose tightly over the bleed nipple and lead it to a bottle with some fluid in it. Keep the end of the tube under the fluid level so it cannot suck air back up the tube.
Otherwise what you did, with the caveat about over travel of the brake pedal & master cylinder, are OK.
