Blackstone Viscosity vs SAE J300 Viscosity
Idaho
Why does Blackstone viscosity differ from viscosity as defined by SAE J300?
On my used oil analysis, and used oil analysis posted here, I have seen:
Blackstone assigns to Pennzoil Platinum 5w30 a 100 degC viscosity range of 9.1 - 11.3 cSt.
Blackstone assigns to Mobil 1 5w30 a 100 degC viscosity range of 8.8 - 11.1 cSt.
Blackstone assigns to Pennzoil Platinum 10w30 a 100 degC viscosity range, of 9.9 - 11.9 cSt.
Blackstone assigns to Mobil 1 0w30 a 100 degC viscosity range of 8.8 - 12.2 cSt.
On the other hand, SAE J300 defines a SAE30 oil as having a 100 degC kinematic viscosity (ASTM D445) range of 9.3 - 12.49 cSt
Why the discrepancy between Blackstone and SAE?
And why does Blackstone assign different viscosities to Mobil 1 5W30 and Pennzoil Platinum 5W30?
SAE specs are for new oil. My guess would be that Blackstone's range is what they would expect that particular oil to be after use. Not all oils of equal weight will get the same numbers from Blackstone, as some have a little higher or lower starting visc, some are more shear prone, etc.
