Over at the Blackstone Labs site I found this article. Colored text is my emphasis:
Questions:
Quote:
Engine owners often stray from manufacturers' recommendations regarding viscosity of oils. The engine builders dyno-test their engines using a specific viscosity oil, so when you use the viscosity they recommend, you are working with a known result. Going to another viscosity is an experiment, but it's usually a harmless one. For the sake of efficiency you want to run the lightest grade oil in your engine possible, within limits. We are seeing that trend for newer engines, for which the recommended grade is getting progressively lighter. The common 10w30 has become a 5w30, and some manufacturers even recommend 5w20 oil. On the other hand, we can't see (in oil analysis) where it hurts anything to run heavier 10w30s or even 10W/40s in modern automotive engines. The heavier oils provide more bearing film, and that's important at the lower end. If your oil is too light, the bearing metals can increase. If the oil is too heavy, the upper end metals can increase. The trick is to find the right viscosity for your particular engine, which is why we suggest following the manufacturer's recommendation.
Questions:
- Any opinions / comments on this section of the article?
- What does "upper end" and "lower end" refer to?
- What are "bearing metals" in a used oil analysis?
- What are "upper end metals" in a used oil analysis?
