So as to not drag Bryanccfshr's thread completely off the rails.
http://www.bobistheoilguy.com/forums/ubb...242#Post1212245
At work, I've got some big bearings, with some big loads on them. Up to 15 longitudinally along the train, ranging from 6" daiameter up to 20".
Generator bearings are 20" diameter, 19"long, and hold around 30 tonnes of mass, spinning at 3,000RPM.
There are three oil systems. (well 4 if you count the hydrogen seal oil, sealing the hydrogen inside the generator)
Main Oil - provides running oil to the bearings, and some hydraulic oil to other systems.
Bearing Oil - provides running oil to the bearings only.
Jacking Oil - provides hydrostatic lift to the bearings when the shaft is not turning fast enough to manufacture a wedge greater than the height of the asperities.
Shaft spins at 3000RPM, on ISO 32 oil that leaves the bearings at around 85C.
When off line, the shaft rotates at 4RPM until cool. Jacking oil provides the lift to the heaviest loaded bearings, at about a gallon a minute to each bearing. This is only on the heaviest loaded bearings (1 through 10 on the 15 bearing machine, and 5 though 10 on the 11 bearing machine, which has tilting pad journals for the first four, that can lift the shaft during barring).
On run-up, the machine is barred at 4RPM on jacking oil (lift), and Main Oil (lube/cooling etc.), at 800-1000RPM, the jacking oil is stopped. On rundown, it comes back in at 400RPM (I've never seen damage to a bearing when the shaft has rotated to a stop from speed without jacking oil).
Would never try shaft turning (barring), or attempt run-up without it.
During maintenance, the jacking oil is used to lift the shaft to rotate it for alignments etc...takes 10-15 minutes for the oil to escape from between the shaft and journal to get a reliable dial gauge reading on it.
Some maintenance crews use STP on the bearings pour it over the shaft, wrap a sling from the overhead crane (think strap type oil filter wrench), and lift/turn at the same time. The STP appears to squeeze so slowly that a single application will last days.
