quote:
Originally posted by VaderSS:
I see that all the time, it was a cheap car, so I won't take care of it...
I bought this car, a 1996 Ford Contour, for $4500 with 72,000 miles on it about 2 years ago.
These are the emissions test results for the last 3 emissions checks:
As of 2/9/04, with 97394 miles:
15MPH
HC ppm limit 81, reading 9, PASS
CO% limit 0.45, reading 0.03, PASS
NO ppm limit 647, reading 2, PASS --NOT A TYPO
Dilution 15.2 PASS
25MPH
HC ppm limit 78, reading 13, PASS
CO% limit 0.43, reading 0.04, PASS
NO ppm limit 585, reading 2, PASS -- NOT A TYPO
Dilution 15.2 PASS
As of 11/08/01, with 71184 miles. Test results, with the exception of the 15MPH CO%, are noticeably worse than those above(this test done a few months before I bought this car):
15MPH
HC ppm limit 81, reading 35, PASS
CO% limit 0.45, reading 0, PASS
NO ppm limit 647, reading 103, PASS
Dilution 14.80 PASS
25MPH
HC ppm limit 78, reading 47, PASS
CO% limit 0.43, reading .01, PASS
NO ppm limit 585, reading 418, PASS [BARELY PASSED
Dilution 14.81 PASS
As of 05/25/2001, with 71178 miles. It failed this test, I believe it sat parked between 05/25/2001 and 11/08/01 (this is prior to my ownership of this car):
15MPH
HC ppm limit 81, reading 3, PASS
NO ppm limit 647, reading 69, PASS
Dilution 14.60 PASS
25MPH
HC ppm limit 78, reading 5, PASS
CO% limit 0.43, reading 0, PASS
NO ppm limit 585, reading 1003, FAIL
Dilution 14.50 PASS
I think I did a public service by buying this car and getting it to run so clean!
What did I do? I replaced the plugs + wires, the two oxygen sensors, and I sprayed about half a can of B12 Chemtool Carb and Choke cleaner into the intake with the engine running. Total cost of about $200 and gas mileage is WAY UP.
Right now I've got Auto-RX in it to see if it will fix a slight rear main seal leak.
This was the car that needed the unscheduled alternator replacement because the battery developed a shorted cell and the P.O. thought that jump-starting the car was cheaper than buying a new battery.
