Originally Posted By: Pop_Rivit
I'd be interested in seeing the research you've done to back up your "nasty stuff" assumptions. Can you point me to the research that concludes it's better to floor your engine and shut it off rather than allow it to idle for a moment and shut it off? Do you have a link to the research you (or someone else) has done? I'd also be interested in knowing how long the "floor it" part has to last before the engine can actually be turned off. 10 seconds? A minute? And how much longer can an engine last if subjected to your "floor it" procedure? The research should be able to at least provide answers so it can be discussed.
Please provide the actual data (versus the current conjecture) so we can all be just as enlightened.
I've seen the inside of more than a couple engines, all of which (to my knowledge) were never subjected to your "floor it and shut it off" procedure, and never seen the "nasty stuff" to which you refer, so I'm very interested in seeing your research that proves the contrary.
I didn't actually say "floor it," rather I said REV it up and that is subject to evaluation. What I am after is to see if maybe that would be a better procedure and if so, at what RPM, perhaps 2000, I don't know.
As for the "nasty stuff" I thought it was pretty much common knowledge that engine blow by happens and is not good, so I gave it a cutesy label. Not nasty stuff coating the insides of the engine, but nasty stuff that soaks into the oil and degrades it.
