Beta??
Kentucky
I am looking at a spec sheet and it says: Beta 2/20=15/31. Nominal 19 microns. What is this telling me?
Thanks much
purely a guess but it could refer to the statistical testing of the media. Beta is a way of measuring probability of error in their testing method.
if that is the case then it is not very useful to the end consumer. Hopefully I am way off and beta is some type of measure in filters.
do you have a link to the spec sheet?
Does this then mean that the above filter would be 50% at 15 microns and 95% at 31 microns?
I am probably missing something or not underestanding something, but, a filter with a Beta 2/20=15/31 doesn't sound like a very good filter. 31 microns is .0012 inch and 19 microns is .0007 inch. What about filters that talk about 10 to 12 micron filtration?
They're typically called bypass filters, Frank. It depends on what efficiency level they're filtering at.
10um nominal (single pass 50%) isn't all that great.
15um at 98.67 (Beta 75 multipass test) is stellar.
The 2/20=15/31 is average ..or typical or whatever
It's not outstanding ..it isn't lousy
It is what it is ..and that's at least OEM spec.
