You'll be fine it could have been the pads off gassing.
Brake and carb cleaner both have the same ingredients just different proportions.
Yea they stopped smoking with the next drive.....
My dad said it could of been b.c really only loaded brake cleaner on the part the pad touches both sides and the parts of the rotor the pad dont touch i just sprayed it a lil bit less however it did STOP
Also how come these ROTORS get so HOTTTTTTTTTTTT
My other rotors I could drive and they werent as hot.. These rotors If I touch them after I drive it will burn the [censored] outta ur finger.
My old ones never got that HOT..
Perhaps new rotors do that... Perhaps they are made to take the heat so the pad and the calipar dont.
I did a first class job with new hardware and took the caliper bolts out and cleaned them and re greased em.
I mean i took my time and did a good job
so what you think about why they get hotter???
or Perhaps the old ones got hot but I never really noticed it.
It stops much better now and sooo smooth
I mean i can be going 50 MPH and take hands off wheel and hit the brakes * NOT SLAM * but hit brakes and it stops in a perfect line... Long as its a good road.
also its stops much faster with new ROTORS also new pads
Wearever PLATINUM
I had Wagner Thermoquiet on there before and tell you the truth I was not happy with them on this car..
when I went from Reverse to Drive they would make a CLUNK Sound b.c the pads were to short.
The new pads went in tighter but not to the point to where I had to file off anything..
they went on perfect
also I read Raybesto makes Wearever...
Im just glad I have all new hardware in there b.c the old was all rusted out.
anyways.. about the heat?? What you think?
Wearever PLATINUM
