- Joined
- Apr 12, 2024
- Messages
- 68
On my 1996 chevy 5.7 350 small block 1500 when I turn the wheel all the way one way and hold it grenades my power steering, blows up the pump. Why does it do this?
Why are you doing this?hold it
Often that is reused on when switching pumpsI thought pumps had a pressure relief valve to prevent catastrophe.
Why??On my 1996 chevy 5.7 350 small block 1500 when I turn the wheel all the way one way and hold it grenades my power steering, blows up the pump. Why does it do this?
Our 2011 is starting to leak. My wife can't relate to what you say. When I am driving her car, it's getting more difficult as the assist is just not there at idle--I "kiss" the lock and immediately back off. She drives normally and then tells me I better put some cardboard under as she "felt" the wheel go all the way to the end, as if the car did it on its own.While it does sound like you have a problem in your p/s system, it is never a good idea to hold your steering all the way to the lock, at least on GM cars. I have owned a lot of GM cars, and the p/s pump on every one of them would whine if I held the steering wheel all the way to the lock.
